2003 Subaru Outback Idle air control valve, catalytic conve
2003 SUBARU OUTBACK
160,000 MILES • 4 CYL • AWD • MANUAL
FLITZERBLITZER
I got fuel in the cat. The cat. is broken.
Can that be caused by a malfunction of the idle air control valve?
What else can it be caused by?
Thank you,
Flitzerblitzer
Sep 6, 2010 at 10:13 PM
Hi flitzerblitzer, Welcome to 2carpros and TY for the donation
I recommend you check the fuel injectors and fuel pressure regulator if its leaking-if not could be coming from the oxygen sensors/CTS staying in the open loop mode and computer giving fule when not needed.
Sep 8, 2010 at 9:03 AM
