HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Subaru
Outback
Engine
Timing Belt
1996 Subaru Outback timing belt
GREEN SUEBEE
MEMBER
1996 SUBARU OUTBACK
4 CYL
AWD
AUTOMATIC
106,000 MILES
I have a 1996 subaru outback with a broken timing belt. The engine is a 2.5 liter SOHC type. Is this engine an "Interference" fit type?
Monday, January 7th, 2008 AT 9:38 PM
MECHANIC
Hi there,
this motor should not damage valves, but it is good practice to check engine compressions as a precaution.
Mark (mhpautos)
Monday, January 7th, 2008 AT 10:09 PM
Please
login
or
register
to post a reply.
Related Timing Belt Content
Timing Belts & Gaskets
My Question Is On A Subaru H4 Engine. Is There A Timing Belt Or A Chain? Also Does Subaru Use Rtv Material For There Gaskets? Thank You...
Asked by
robertvanniel
1 ANSWER
2002
SUBARU OUTBACK
GUIDE
Timing Belt
Automotive combustion engines require either a timing chain or belt to keep the camshaft to crankshaft correlation correct as part of the design of the engine. A timing belt...
2003 Subaru Outback Idle Air Control Valve, Catalytic...
I Got Fuel In The Cat. The Cat. Is Broken. Can That Be Caused By A Malfunction Of The Idle Air Control Valve? What Else Can It Be Caused...
Asked by
flitzerblitzer
1 ANSWER
2003
SUBARU OUTBACK
Oxygen Sensors - Subaru
2001 Subaru Outback H6, How Many Oxygen Sensors?
Asked by
katdryden
1 ANSWER
1 IMAGE
2001
SUBARU OUTBACK
Changed Engine Now No Injector Pulse
2000 Model 5spd We Put A 03 Impreza Automatic Engine In It Changed Intake Wiring Harness Etc, But Didnt Have Spark Or Injector Pulse Now We...
Asked by
curtisauto
2000
SUBARU OUTBACK
1999 Subaru Outback Oil Change
I Was Changing The Oil Filter When A Seal Fell Out And I Don't Know Where The Seal Goes. It Seems To Be The Same Diameter As The Oil Filter...
Asked by
subie1966
1999
SUBARU OUTBACK
VIEW MORE
Serpentine Belt Replacement Saturn Vue
Serpentine Belt Replacement Chevy 1500
Serpentine Belt Replacement Ford F-150 5.4L V
