No, not really. Everything sounded ok, untill you wrote that he said your car ran bad because he put the tining belt on too fast. What did he mean by this? The belt only goes on one way that I know of. Did he not pt the cover on right. Did he resolve that issue? By the radiator, not many have that screw to release the coolant. Are you loosing coolant? That should be an easy fix if it is just the drain plug. Donate for a pros help
SPONSORED LINKS
Monday, January 19th, 2009 AT 7:57 PM
