1993 Subaru Legacy Transmission Pump Not Working
SUBARU
PHILB123
have just replaced engine in 1993 legacy and now the transmission is not functioning. symtoms are no fluid is being pumped to the cooler and there is no response from transmission when the car is put into drive. it would seem to me that the drive has been damaged when fitting up the new engine. in this case i suspect that the trans will have to be removed and the coupling inside the gearbox will need to be replaced.
Apr 1, 2006 at 7:48 AM
LOSONE
  • 1,616 POSTS
It sounds like the mechanic jamed the flywheel and either locked or broke the front pump assy. An expensive mistake or you may be lucky and it will spring back in place. the tranny still has to come out.
Maybe if you drove it on the left side of the road like here it would work better!! ha ha a small joke Let me know
Apr 1, 2006 at 8:28 AM
PHILB123
[quote:e403b6b9e6="losone"]It sounds like the mechanic jamed the flywheel and either locked or broke the front pump assy. An expensive mistake or you may be lucky and it will spring back in place. the tranny still has to come out.
Maybe if you drove it on the left side of the road like here it would work better!! ha ha a small joke Let me know[/quote:e403b6b9e6]
ouch, just as i suspected, i liked the small joke as it put a smile on my face that hasnt been present since this occurance.
cheers phil
Apr 1, 2006 at 8:35 AM
Suggested Repair
Remove the transmission and inspect the front pump assembly. A jammed flywheel during engine installation may have locked or broken the pump; it might spring back, but the transmission still has to come out for inspection and repair.
Conversation Summary
After an engine replacement in a 1993 Subaru Legacy, the transmission does not respond in drive and no fluid is pumped to the cooler. The owner suspects the drive coupling was damaged during installation. The expert says the flywheel was likely jammed, locking or breaking the front pump, and the transmission must be removed to check and repair it.
