1993 Subaru Legacy Fuel Gauge Drops
SUBARU
OHLDAR THE ELDER
My 1993 Subaru Legacy LS, AWD, 2.2L engine, auto trans, 134,000 miles, gas gauge goes from almost 1/2 full to dead empty, and will stay there, sometimes for 1-2 days. Can I sanely replace the sender or whatever, or is it too much trouble to work with?
Sep 29, 2007 at 12:54 PM
MERLIN2021
  • 17,250 POSTS
I noticed the "elder" in your handle, if that's true I would leave it alone! A lot depends on if you live in a rust belt state? This will get ugly with a 93 in that region...If you are in a good climate, use up most of the gas or siphon it out, leave about a gallon. remove the lines, Drop the tank, remove the spanner nut, pull out the tank unit and replace! Easy eh?
Sep 29, 2007 at 1:14 PM
Suggested Repair
If the vehicle is in a rust-prone area, the tank job can get difficult and may be better left alone. In a good climate, use or siphon most of the fuel, leave about a gallon, disconnect the lines, drop the tank, remove the spanner nut, and replace the tank sending unit.
Conversation Summary
The owner of a 1993 Subaru Legacy says the fuel gauge drops from nearly half full to empty and can stay there for one or two days, and asks whether the sender can reasonably be replaced. The expert says rust conditions matter and recommends leaving it alone in a rust-belt climate; otherwise, drain most of the fuel, drop the tank, and replace the tank unit.
