1998 Subaru Legacy Key Stuck
SUBARU
MACKLIN
Subaru Outback Legacy 1998 2.5 Liter 150K miles. I am suddenly able to move the auto shift lever out of park with the engine off and without pressing the brake pedal. Also, I am unable to remove the key from the ignition. Needless to say I now have safety and security concerns.
May 17, 2007 at 7:36 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you need a new ignition switch.If it is stuck in on position,t he shift lock could be disabled. Unhook the lockout solenoid on the shifter and see if the key returns
May 17, 2007 at 8:45 AM
Suggested Repair
Replace the ignition switch if it is stuck in the on position, which can disable the shift lock. Unhook the shifter lockout solenoid and check whether the key then releases.
Conversation Summary
The owner of a 1998 Subaru Legacy Outback says the shifter can be moved out of park with the engine off and without pressing the brake, and the ignition key cannot be removed. The expert attributes this to a faulty ignition switch stuck on and recommends unhooking the shifter lockout solenoid to see if the key returns, then replacing the ignition switch.
