1994 Subaru Legacy Shifter Stuck in Park
1994 SUBARU
PAULME12
Hi, I have a 1994 Subaru Legacy 4 door, 6 cylinder car with 127,000 miles on it and I'm having trouble with the shifter. When I try to shift out of park into drive it doesn't want to release, I have to try several times before it works. What is my problem? Thanks, Brenda
Jul 22, 2007 at 8:56 AM
2CARPRO JACK
  • 11,533 POSTS
That could be either the switch on the brake pedal, the shift lock control unit, or the solenoid on the shifter.First check fuses 1, 2 , 12. Then test for power at the white/black wire on the brake switch when brake is applied. If ok, then test for power at the solenoid on the shifter when brake applied, should have power to the red/green wire. If not it most likely is the Shift Lock Control Unit
Jul 23, 2007 at 12:49 AM
Suggested Repair
Check fuses 1, 2, and 12. With the brake applied, test for power at the white/black wire on the brake switch, then at the red/green wire on the shifter solenoid. If the solenoid has no power, the shift lock control unit is the likely cause; the brake switch or shifter solenoid may also be at fault.
Conversation Summary
The owner of a 1994 Subaru Legacy with 127,000 miles says the shifter often will not release from park into drive and must be tried several times. The expert says the cause could be the brake pedal switch, shift lock control unit, or shifter solenoid, and recommends checking fuses 1, 2, and 12, then testing brake-switch and solenoid power with the brake applied.
