1991 Subaru Justy Won't Start
SUBARU
RPG
hi, friends, i have an strange problem, i got a 91 subaru justy 1200cc 3 cilinders, in the past days he doesn´t want to turn on, the exhaust smell like not burned gasoline, and i changed the coil recently and got good spark, maybe that strange carburation system, or some electrical problem, i don´t know, i need help, he start, i turn off, he starts again, turned off again and he doesn´t start, i´m desperate, thanks
Jun 5, 2006 at 2:33 AM
  • 110,248 POSTS
Start by making sure the choke butterfly isn't sticking shut. Also, check to see if the carb is dumping fuel into the engine. There could be a problem with the float.
Let me know what you find.
Feb 28, 2009 at 5:37 AM
Suggested Repair
Check that the choke butterfly is not sticking shut and that the carburetor is not dumping fuel into the engine. Inspect the carburetor float for a fault.
Conversation Summary
A 1991 Subaru Justy 1200 with a three-cylinder engine starts, then fails to restart, and the exhaust smells of unburned gasoline. The coil was recently replaced and spark is good. The expert recommends checking for a sticking choke butterfly, excess fuel from the carburetor, and a possible float problem.
