1993 Subaru Impreza L Cold Start Problem
SUBARU
TMS7887
I have an 93 Subaru Impreza L and have trooubles starting it early morning when it is cold. I changed the spark plugs and the fuel pump laready. the only way i get it to start is if i spray some cold start fluid in the air filter or sit and keep trying to crank it till it starts. What else could be the problem that i am looking over?
Mar 24, 2006 at 2:16 PM
CF_ANDERSON
  • 20 POSTS
Not to insult your intelligence but what about your battery? They are one of easiest do it yourself jobs. I have a 1991 Loyale and one day it went dead. Bought a new battery and it died the next day. I figured out that my alternator was bad too. Put in a new alternator, had volts going from the alternator to the battery but the car died after I turned it off. After hours of checking wiring connections I forgot the obvious; my new battery was a lemon. Your car battery gage (on your dash board) should read above the "12". If not, you may need a new battery. If you don't have a voltmeter to get exact reading, go to your local auto parts store and ask them to check your battery for you. If your battery is bad, buy a new one right there and usually they will install it for free because you bought from them. Remember, always ask about total cost before you have them touch your car. Most auto parts store employees are not certified mechanics.
Mar 26, 2006 at 9:33 AM
TMS7887
I did that already cause that was the first thing i thought about when it stated and i have also done a complete tune up and changed the fuel filter.
Mar 27, 2006 at 10:11 AM
  • 75,988 POSTS
[quote:50b3c36a14="tms7887"]I have an 93 Subaru Impreza L and have trooubles starting it early morning when it is cold. I changed the spark plugs and the fuel pump laready. the only way i get it to start is if i spray some cold start fluid in the air filter or sit and keep trying to crank it till it starts. What else could be the problem that i am looking over?[/quote:50b3c36a14]
Check your fuel filter also the fuel pressure with a gauge, before we take it to the Ignition system.
Mar 27, 2006 at 11:53 AM
Suggested Repair
Check the fuel filter and measure fuel pressure with a gauge before investigating the ignition system.
Conversation Summary
A 1993 Subaru Impreza L is hard to start on cold mornings. The owner replaced the spark plugs and fuel pump, later reported a tune-up, fuel filter replacement, and a battery check, and can start it only with starting fluid or repeated cranking. Another user suggested the battery and charging system. The expert advised checking the fuel filter and measuring fuel pressure with a gauge before moving on to the ignition system.
