Subaru Forester 2004 tire replacement
2004 SUBARU
ELLAJOY60
I have an all wheel drive Forester, the left rear tire blew out and now the tire store tells me that their
manual states that all 4 tires need to be replaced at the same time or my transmission will be affected. One of the tires was replaced when I got hit a year ago-so if the replacing all four tires at once rule is correct did I mess up my transmission after my accident?
Mar 31, 2007 at 6:50 PM
SCUBARU
  • 71 POSTS
Ok here is the deal .On a Subaru AWD vehicle it is important that all of the tires have close to the same amount of tread on them.Reason being is a tire as the tread wears, the tires overall circumference becomes smaller.lets say you had 3 tires with 7/32 of tread remaining versus and the forth had 12/32 the tire with 12/32 would actually spin slower than the rest.On a Subaru The TCM(transmission control module) would reconize the speed difference and think the other three tires were slipping and apply more power to the one that is spinning slower while decreasing the power to the three that were spinning quicker.But if the road conditions arent causing the difference in wheel speed readings then thats where transmission damage can occur.So a good rule of thumb is no more than 3/32 difference front to rear and no more than 2/32 side to side.As far as the potential for damage it just depends on how much difference there was between the tire you replaced and the other ones on the vehicle .I hope that helps you.
Apr 1, 2007 at 1:00 PM
