starting issues
SUBARU
GAB2327
have a 1990 subaru legacy front wheel drive manuel transmission. it has aprox 165k miles. it has a hard time starting up on the first start. Requires excessive pumping of the gas pedal before it will start up. after the first initial startup the car will start up fine thereafter. I have already changed the spark plugs, spark plug wires, fuel filter, air filter, oil filter. i have also checked the fuel pump to see if it is pumping the fuel and that seems to be working fine. Any suggestions that you might have would be greatly appreciated! thanks
Apr 14, 2007 at 9:23 AM
COSMO
  • 347 POSTS
Steering axis inclination a.k.a. turn out in turns
Also see bump-steer and ackerman
Cosmo...
Jan 25, 2007 at 12:38 PM
RAVENON
  • 5 POSTS
Hi..Check cold temp sensor and airflow meter are operating properly..
Hope that helps
Raven
May 31, 2007 at 12:31 PM
