Subaru L Series Wagon, 1985, 1.8 L, 245,000 klms. A few days ago my car started surging when I tried to excellerate. Now when I press the excellerator the car slows down and jumps. When I try to drive from stop it cuts out. I took it home and removed the air filter cover. The air filter was covered in oil as was the throttle body and carby. I sprayed carby cleaner as recommended and changed the air filter. Car runs but I fear if I drive it the oil will lak back onto the air filter. Any advice you have would be greatly appreciated.
1985 Subaru L Series Oil in Filter
SUBARU
Hi Guys,
Aug 18, 2007 at 3:29 PM
Hi there,
The oil is due to the worn condition of your engine, your rings & cylinders are worn and excessive crankase pressure is forcing this oil in the form of a mist through the breathing system and as it cooles it condenses back into the oil that is collecting in the air cleaner. There is no simple fix short of rebuilding the engine, but in the short to medium term make sure that the oil is changed when due, keep the P.C,V. valve clean and remove the air filter and clean any excessive oil deposits up befor it foules the filter. This is the normal signes of a worn engine, but it's not fatal in it's self, keep an eye on things and it should keep on keeping on for some time to come.
Mark (,mhpautos)
Mark (,mhpautos)
Aug 18, 2007 at 7:01 PM
Suggested Repair
Oil mist in the air cleaner is from worn rings and cylinders and high crankcase pressure. There is no simple fix short of an engine rebuild. In the meantime, change the oil on schedule, keep the PCV valve clean, and remove and clean oil from the air filter before it fouls.
Conversation Summary
A 1985 Subaru L Series wagon with a 1.8 L engine surged, slowed, and cut out under acceleration, and the owner found oil on the air filter, throttle body, and carburetor. After carb cleaner and a new filter the car ran, but oil was expected to return. The expert said worn rings and cylinders were forcing oil mist through the breather into the air cleaner. A rebuild is the real fix; short term, change oil when due, keep the PCV valve clean, and clean oil off the filter.
