engine rvs dropping
SUBARU
SCOOBYDOO
hi, i have a 1998 subaru impreza turbo with 56.000 on the clock.i have an annoying problem with the tickover,when i,ve been out on a run and come to a junction or traffic lights the engine rev s drop down to approx. 150/200 rpm then stabilise to normal after 5/10 seconds,occassionally the car stalls.had car on diagnostic but no faults showed up,any ideas would be appreciated,thanks
Mar 7, 2006 at 6:14 AM
CF_ANDERSON
  • 20 POSTS
Not too familiar with Subaru Impreza but your problem may be very easy. It sounds as if its your idle speed adjuster. Usually it's just a screw located on the throttle body. Let me know if you need more help.
Mar 7, 2006 at 9:26 AM
WRX246
  • 39 POSTS
yay
someones car doing the same as mine
at the moment my car is in auckland & the guys are trying to find the fault
can you email me a list of what you have checked & i'll looki through my subaru manuals
emailis carlisa123@gmail.com
thanks carlisa
Jul 22, 2007 at 1:16 PM
WRX246
  • 39 POSTS
i'll keep you posted as to what the end result on my car is
so you can fix yours
thanks
Jul 23, 2007 at 7:11 AM
