1992 Subaru Loyale Cold Hesitation
SUBARU
YNOTCARRIE
1992 subaru loyale with 134232 miles. I have recently inherited this car. The old owner recently had timing belt and water pump replaced, in addition to replacing the plugs, wires, air filter, rotor, distributor, and he told me that the injecters have just been cleaned. Nothing done to fuel filter or fuel pump. Car appearred to be running fine until the recent cold weather, I have had the car for about 4 days.When starting the car, the car will quickly stall and then after two or three tries it will keep running. The car hesitates and back fires before stalling out if I press on gas pedal sharply. If I ease on the gas pedal it will slightly hesitate but stay running. This problem seems to stop once car is fully warmed up or if I am driving at a steady speed. Do you have any suggestions
Jan 9, 2007 at 1:01 PM
2CARPRO JACK
  • 11,533 POSTS
Definitly have the fuel pump checked for pressure.Its the check engine light on? have the PCM scanned, could be the coolant temp sensor or the Mass Airflow Meter if so equipped
Jan 9, 2007 at 11:16 PM
MATHIASO
  • 1,209 POSTS
And always seeck to determine the root cause of faillure to prevent repeated problems.An example is a fuel pump that fails due to debris in the fuel tank.Replacing the pump may correct the driveability problem, but the root cause of the pump failure was the dirt in the fuel tank.
Jan 10, 2007 at 2:24 AM
Suggested Repair
Check fuel pump pressure and scan the PCM, especially if the check engine light is on. Also test the coolant temperature sensor and the mass airflow meter if equipped. If the pump is weak, look for tank debris as the underlying cause.
Conversation Summary
A 1992 Subaru Loyale with about 134,000 miles stalls on cold starts, hesitates, and backfires under sharp throttle, then runs better once warm or at steady speed. Recent work included the timing belt, water pump, plugs, wires, air filter, rotor, distributor, and injector cleaning, but not the fuel filter or pump. Experts recommend checking fuel pump pressure, scanning the PCM, and considering the coolant temperature sensor or mass airflow meter, while also finding any root cause such as tank debris.
