1998 Other Subaru Models hesitates
1998 SUBARU
175,000 MILES • 6 CYL • AWD • AUTOMATIC
LILNEMO208
i have a 98 subaru legacy outback. when i go to accelerate from a stop, the car creeps forward then eventually gets a little boost and starts driving normal. (not normal, but it runs a little rough). this is WORST when the car is cold and gets semi better as the car warms up and doesnt happen at each time. ive had the fuel pump done and no better
Apr 16, 2010 at 7:07 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 16, 2010 at 7:11 AM
