99 Subaru Forester Overheating
1999 SUBARU
GVPMAN
My 1999 Subaru Forester has been overheating for quite some time, and the heater doesn't usually work. I've had the radiator flushed and the thermostat replaced recently, but neither helped. Yesterday it overheated to the point where smoke was coming from the engine. When I opened the hood, I noticed that coolant had splashed out from somewhere and was sitting in small puddles on top of the engine. Also, when I took off the radiator cap, there was no more coolant inside and there's brown, rust-like liquid around the bottom of the cap; however, the overflow reservoir was filled way past the fill line, which has never been the case. The engine has been hesitating for a while too, but I have no idea if that's related.
Mar 9, 2006 at 12:32 AM
ACR
Possible air lock in the cooling system keeping the pump from circulating the fluid. Might also not hurt to consider checking for head gasket problems. A compression check will help diagnose this. A compression-to-cooling system leak will cause all kinds of nasty symptoms ranging from overheating to surging to clouds of white smoke out the pipe.
Mar 17, 2006 at 1:15 AM
