1999 Outback overheating
1999 SUBARU
MTNBIRDLADY
Hi, I have a 1999 Legacy Outback Wagon AWD 5 speed. I purchased it new in November 1998. I have been faithful in servicing it. After a speedometer problem (fixed by replacement at 61,020). I now have about 130K (old + new) on it, but I don't know how many miles I drove that weren't recorded because of the speedometer/odometer problem.
I had trouble with it this weekend doing a 400 mile trip one way. When I hit stop and go traffic in high heat and AC on, the car jumped to 3/4 H on the gauge. I pulled over and turned the heater on full blast. The heat gauge immediately went down to normal. There were no further incidents. Then on the return trip, I stopped to run into the store. I left the AC on and less than 5 minutes later, it was on H. I immediately turned the heater on and it went down quickly. When I'm moving, the car is fine with the tempurature, but if I slow after driving for a long time it rises. I noticed yuck (residue) in the coolant reservoir and when the engine is on during the hot driving, it bubbles too. Now I noticed the coolant is very low. I drove it today, with not a problem, but only about 15 minutes at highway speeds.
I keep reading about the blown head gasket problem. I'm guessing I have that same problem. Tell me if I'm wrong. Now, if I am right, is there any way to fix this myself. My subaru dealer told me this could happen and that it is happening with 9 out of 10 cars around this mileage and it will cost me $2000 to fix it. Is there any way to fix this without pulling the engine? Are there any easy manuals to tell me how to do this? Should I even bother? Will the new gaskets even last? Should I junk the car? Loved it before this weekend.
Jul 15, 2007 at 7:47 PM
  • 75,988 POSTS
Cheap fix try the thermostat and radiator cap 1st. Or
have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Jul 15, 2007 at 11:32 PM
WRX246
  • 39 POSTS
one suggestion
have you got acess to a air compressor ??????
remove spark plugs remove the radiator cap & then one at a time blow compressed air into the cyclinders if there are bubbles appearing in the coolant you'll know for sure that the head gasket is gone
if you want more help please feel free to email me
carlisa123@gmail.com
Jul 16, 2007 at 1:25 PM
