2001 Subaru Legacy Slow Crank Stall
2001 SUBARU
OUTLANDER92
2001 subaru legacy outback, 180,000, AT - I had work done on my brakes, exhaust, and catalytic converter back in July, and ever since then my car has been turning over slowly, like the battery is getting weak, but it always starts. Granted, it's old, but it hadn't done this before the work. Today I was stopped behind traffic on a hill, and went to accelerate fast as the traffic moved, and the car totally stalled. I turned everything off, then on again, and it started as it usually does - slow but sure. I noticed that the trip meter and clock had reset as well, suggesting the battery had cut out, but it did start, and it started like usual 9 hours later when I left work. So, is this a weak battery issue or something else? Thanks!
Sep 14, 2007 at 10:41 AM
  • 31,937 POSTS
Hi there,
I would have the battery load tested, this will give you a fair indication as to the condition of the battery, next get the charge rate tested, both these tests will take all of 2-3 min to do. I would also have the battey earths checked, you may have a poor earth return causing the slow cranking and other electrical faults.
mark (mhpautos)
Sep 15, 2007 at 12:21 AM
Suggested Repair
Load-test the battery and test the charging rate, then inspect the battery ground connections for a poor earth return that could cause slow cranking and electrical dropouts.
Conversation Summary
A 2001 Subaru Legacy Outback with 180,000 miles began cranking slowly after brake, exhaust, and catalytic converter work, though it still started. It later stalled when accelerating from a stop on a hill; the trip meter and clock reset, suggesting a brief power loss, then it restarted slowly as usual. The expert advised a battery load test, a charge-rate test, and a check of the battery earths for a poor ground return.
