1986 Subaru Wagon Losing Power
1986 SUBARU
JOAN
I was driving my Subaru this afternoon when the engine started running rough and losing power fairly quickly. I had it towed to my mechanic who thinks it may the the timing belt.
How big of a job is it to replace the timing belt?
Thank you!
Joan
Nov 5, 2007 at 11:09 AM
  • 31,937 POSTS
Hi there,
These engines have two timing belts, one for each bank, so if one has failed it will be running on only 2 cylinders. To change both belts should only take about 11/2 -2 Hrs tops. Best to have the tensioner and idler pulley bearings changed at the same time.
Mark (mhpautos)
Nov 5, 2007 at 1:14 PM
Suggested Repair
Replace both timing belts and, at the same time, the tensioner and idler pulley bearings. The job is estimated at about 1.5 to 2 hours.
Conversation Summary
The owner of a 1986 Subaru wagon said the engine began running rough and losing power and was towed to a mechanic who suspected the timing belt. The expert explained that these engines have two timing belts, one for each bank, so a failed belt would leave the engine running on only two cylinders. Replacing both belts should take about 1.5 to 2 hours, and the tensioner and idler pulley bearings should be replaced at the same time.
