1991 Subaru Legacy Power Loss
1991 SUBARU
JENSUBARU91
Hi! I have a 91 Subaru Legacy sw (4wd) 180K, that I just bought...it seemed to run really smooth for about a week, and then it started making a rhythmic sputtering sound from the hood end of the car. This would only happen at about 25mph and over and only when I was pressing on the gas. The sound was very quiet, I thought maybe it just needed an oil change/fluid check, better gas than the cheepest(it had been sitting for five months before I bought it I found out later) but after I did all those things the sound just got louder and louder and I began losing power (car takes very long time to get up to speed)
Is this something that will hurt my car if I don't get it fixed immediately(like today) or can I shop around for an auto mechanic for a week..Autozone told me it sounds like either the cataliytic converter or the exhaust donut(or both?) Does that sound right? Also I've heard the cat. converter for subaru can be fit with a universal part....am I better off getting the subaru one? One last thing, what is a fair price for a repair on a cat. converter or a replacement (autozone said $91 for the part, but I'm sure the labor will be a lot more, and I don't have much to spend) Sorry this is so many questions, I'm really grateful for this site! Thanks so much!
Oct 11, 2007 at 2:02 AM
2CARPRO JACK
  • 11,533 POSTS
If the cat is plugged, it can cause exhaust leaks elsewhere in the system from the excessive backpressure.A universal cat would probably be ok for your car, have a muffler shop install it , will be fairly cheap.Might get a better deal if you buy the cat and have him isntall it.If the donut or gaskets are blown, you will hear it after the cat has been replaced, then it can be fixed.I would take care of it asap, will eventually damage the engine internally
Oct 11, 2007 at 5:17 AM
Suggested Repair
Have a muffler shop check for a plugged catalytic converter and install a universal converter if needed; fix any exhaust donut or gasket leaks afterward. Repair promptly to avoid internal engine damage from excessive backpressure.
Conversation Summary
The owner of a 1991 Subaru Legacy with 180,000 miles reported rhythmic sputtering under acceleration above about 25 mph that grew louder and caused power loss. A parts store suggested a catalytic converter or exhaust donut. The expert said a plugged converter can create exhaust leaks from backpressure, a universal converter installed by a muffler shop is usually acceptable and cheaper if the owner supplies the part, and remaining gasket noise can be fixed afterward. The repair should be done promptly to avoid internal engine damage.
