1998 Subaru Legacy Front Driver Headlight
MICHELLEDUVALL1
  • 1998 SUBARU LEGACY
  • 6 CYL
  • AWD
  • 14,000 MILES
When the headlight goes out, does the whole unit need to be replaced or can you just replace a bulb?
Wednesday, January 7th, 2009 AT 2:12 PM
MIKE H R
  • 3,094 POSTS
You can just replace the bulb. You do have to take the lens housing out. There is a bolt on top under the hood that needs to be taken out and then the housing can be wiggled out. Once the bulb is replaced then install in reverse order.
Tuesday, January 27th, 2009 AT 9:25 AM
