1997 Subaru Legacy oil leaks
75,000 MILES • 4 CYL • AWD • AUTOMATIC
LIZBETH61
car is a legacy outback.Had a large oil leak repaired 4 months ago .cam seal water pump crank seal oil pan seal trans pan seal valve cover gasket and oil filter replaced. The car is again leaking oil after 4 months.Where else could the car be leaking oil, it is more than one oil leak.
Nov 28, 2009 at 12:11 PM
KHLOW2008
  • 41,812 POSTS
Hi lizbeth61,
Thank you for the donation.
If the oil leaks stopped after the replacement of the parts concerned and starts to leak again after 4 months, the leaks could be related to those areas.
Without a vusual inspection it would not be possible to identify the source. You would need to get it checked to understand where the leaking is coming from.
Nov 28, 2009 at 2:27 PM
