The car overheats. The thermostat has been replaced, as well as the water pump. The timing belt was also realigned. The anti-freeze level is correct and is brand new. Also we bipassed the heater core. I don't know what else it could be, there is no leaks anywhere either. The heater doesn't work and the car over heats after about 10 minutes of running. What else could it be, and how do I fix it?
SPONSORED LINKS
Monday, April 28th, 2008 AT 10:17 PM
