1995 Subaru Legacy leaking and overheating
PHERFUR
  • 1995 SUBARU LEGACY
Engine Cooling problem
1995 Subaru Legacy 4 cyl All Wheel Drive
my subaru is leaking coolent out of the front of the motor and I was woundering if their is a little hole that leaks when the water pump goes bad any help would mean alot
Monday, July 21st, 2008 AT 6:21 PM
  • 31,937 POSTS
Hi there,
there is a drain hole in the pump and if the seal fails it will leak coolant from there, also get the system pressure tested to check for other leaks as well.
Mark (mhpautos)
Monday, July 21st, 2008 AT 11:20 PM
