Engine Mechanical problem
1992 Subaru Legacy 4 cyl All Wheel Drive Automatic
I was changing the spark plugs and accidentely dropped a small screw down the spark plug hole #1 Cyl. Of course I haven't attempted to even start the car since I'm waiting to get a flexible magnet per Fed X. My question is in case I cannot get the screw out this way (Probing around through the spark plug opening) is it possible to take off the Right Cylinder
Head and put it back on without having to do any adjusting etc. to the lifters, valves, etc? I've been reading through my Chiltons manual for this auto on how to remove and install it, and so far I'll I can tell that I would need to replace is the manifold, valve cover, and the cylinder head gaskets. Is this correct?
Aug 20, 2008 at 1:44 PM
