2002 Subaru Impreza Engine light is on, car won't accelerat
TRIKITTY
2002 Subaru Impreza 4 cyl Four Wheel Drive Automatic
My engine light is on. When i step on the gas pedal, the car won't accelerate like it used to. My RPM won't go up above 3000, so I be driving around 20-30km, but after running for a little while, it picks up the speed again. I noticed that this usually happens in the morning, could you please help.
Feb 3, 2010 at 4:21 AM
  • 75,988 POSTS
If you're refering this engine light as the check engine light your 1st step is have the computer scanned for code/s to find out what's causing it to come On. There's a problem within the engine management system this is your starting point of diagnosis
Feb 3, 2010 at 5:44 AM
