1999 Subaru Forester compressor possible short cycling
1999 SUBARU FORESTER
100,000 MILES • 4 CYL • AWD • MANUAL
HOPELESS_DRIVER
I recently charged my air conditioner with r-134a refrigerant because the gauge said it was a little low. Now, it is fully charged, but I was driving on the freeway today, cruising at about 80 mph, about 75Ëš outside, and noticed that every 15 seconds or so the car would jerk slightly (not very much, but noticeable). I'm pretty sure that it jerks every time the compressor turns on. While feeling the air coming out of the vents, it is very cold when the compressor turns on, but that doesn't seem to last very long because it cycles off so quickly. It just gets very cold, then sort of cold maybe 10 seconds later, then very cold again. Is this abnormal? I don't remember it happened before I added the r-134a, so I'm wondering if there's something I did wrong. The can that I used did not have any AC oil in it, so could this be the problem? Should be car be jerking like that every time the compressor turns on?
Thanks!
Aug 7, 2009 at 5:11 PM
  • 31,937 POSTS
HI there,
Thank you for the donation,
I would start off by having the system pressures checked as there may be a overly high demand on the compressor a nd this is causing your problem, start here.
mark (mhpautos)
Aug 7, 2009 at 7:41 PM
HOPELESS_DRIVER
So I might just have overcharged the system?
Aug 8, 2009 at 4:02 AM
  • 31,937 POSTS
This should be check and eliminated as the cause first.
Mark (mhpautos)
Aug 8, 2009 at 11:27 AM
