Strut assembly
160,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JACOB GARZA
Replacing front struts with OSC quik-fit. Can I use the Q151572L (driver side) for the passenger side as well? They sent the wrong part. I turned the top plate around and it looks the exact same as the old one.
Sep 3, 2017 at 5:03 PM
CARADIODOC
  • 34,413 POSTS
If it looks the same as the old one, why put on the new one?
Okay; enough humor for tonight! Yes, you can use it that way. In fact, there is no such thing as a left or right strut on Chrysler products. You get a pair of struts. There is no such thing as a left or right upper strut mount on Chrysler products. You get a pair of mounts. The springs are the same too. You will notice the struts have two mounting holes for the anti-sway-bar links. You use the one that matches that side of the van. Same with the little bracket the brake hose bolts to.
Some do-it-yourselfers would not figure out to spin the upper mount around. That is why they sell them as left and right quick-struts.
Sep 3, 2017 at 5:24 PM
JACOB GARZA
Very good, thank you. I was pretty sure but you never know. And the CARiD customer service said they would not return it if had already been installed. Have a great day!
Sep 4, 2017 at 8:08 AM
  • 55,628 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Nice work Caradiodoc.
Cheers, Ken
Sep 5, 2017 at 8:53 AM
