Dear Roy, thank you for your advice. The mechanic did the compression test and one piston is frozen, so they've soaked it and will see today if all is not lost. Also they, discovered a hole in the radiator, the coolant reservoir was full. The question is, is it worth high expense to repair?
Saturday, May 18th, 2019 AT 6:43 AM
