Good evening.
What temperature thermostat?
When the engine is running, can you feel air being drawn through the front of the car?
If you power washed the radiator and condenser, you may have closed off the fins from the water pressure. To resolve that, you need a comb for the fins to straighten them out and allow air.
Did you take the temperature of the upper and lower part of the radiator to see if there is a big temperature difference to see if the radiator is working or clogged?
What are the usual parts?
SPONSORED LINKS
Tuesday, June 5th, 2018 AT 5:13 PM
