Engine Cooling problem
1990 Jeep Cherokee 4 cyl Four Wheel Drive Automatic
What controls the engine overheating...is it the thermostat, the coolant fan temp switch or the fan switch. I am going to replace the thermostat, but I dont know if that will fix the problem of the fan not turning on when engine is getting to hot. If I need to replace either ther coolant fan temp switch or fan switch were are they located
Sep 24, 2009 at 12:54 PM
