steering
167,000 MILES • AUTOMATIC
PEARL ROSE MCINTYRE
When you are driving it, and wish to turn left, like at a stop light, it has to be jerked to the right and then jerked to the left to make it turn , because some steering mechanism is messed up. It does great on highways though.
Aug 2, 2017 at 2:29 PM
CARADIODOC
  • 34,414 POSTS
Instead of turning the other way, raise engine speed a little. If that does not help, the best suspect is a worn rack and pinion steering gear. GM had a real lot of trouble with them causing loss of power steering assist on their front-wheel-drive cars.
If power assist does come back when you increase engine speed, a worn power steering pump is a good suspect, but be sure the fluid level is okay first.
Your description of having to turn the other way first is not common. That could involve a worn outer tie rod end or some other part in the steering linkage. The potential clue is turning left and right react differently. Before this becomes a safety concern, the best approach is to have the steering and suspension systems inspected at a tire and alignment shop.
Aug 2, 2017 at 2:49 PM
