Starter problem
2,990,000 MILES
POTGIETER 2468
  • 5 POSTS
Hi there, we have problem with our starter. we put new brushes in and a solenoid, we put it back but the Bakkie doesn't come on at all. it is dead when they take stater out and tried it it start but a soon as they put the starter back in it wont start. what can be the problem? i don't want to go and purchase a new starter if it is not the problem. please help. thank you in advance.
Sep 11, 2019 at 8:11 AM
  • 110,246 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US, so my technical information is very limited.
Now, if the starter works out of the vehicle but not in the vehicle, have you confirmed a good ground from the battery to the engine block? Is there any noise from the starter when you try starting the vehicle? Also, have you checked to see if there is power to the S connector on the starter when the key is in the start position? Have you checked fuses and a starter relay?
Something is preventing power flow at the starter when it is in the vehicle. We need to determine if the S connector is getting power. Follow the directions in this link and let me know the results.
Take care and I will watch for your reply.
Sep 11, 2019 at 12:03 PM
POTGIETER 2468
  • 5 POSTS
Hi there, thank you for your response.
When you put the key in the ignition and turn it nothing happened but the radio comes on, but the Bakkie does not want start at all. nothing it totally dead.even if you can turn the key but nothing happened is not even the speedometer and the wipers do not work.
Sep 11, 2019 at 5:35 PM
  • 110,246 POSTS
Welcome back:
Have you checked main fuses under the hood? Also, have you checked to see if there is power to the starter as described in the aforementioned link?
Sep 12, 2019 at 10:25 AM
POTGIETER 2468
  • 5 POSTS
Hi there, they took out the starter and there is power on the starter but as soon as they put it back in the bakkie nothing happened.
Sep 12, 2019 at 5:24 PM
  • 110,246 POSTS
Welcome back:
On a typical starter, there are two primary connections. One is direct from the battery +. It will have power all the time. The other is on what we refer to as the starter's S terminal. It is a much smaller wire which only receives power when the key is in the start position. If you have power to both and it still doesn't work, check the main grounds to the engine block. If the ground is good, it has to be a starter issue.
Sep 13, 2019 at 10:34 AM
POTGIETER 2468
  • 5 POSTS
Hi, thank you for your help. we needed to buy a new solenoid back is been working now .thank you for all your help i really appreciate it.
Sep 13, 2019 at 7:35 PM
  • 110,246 POSTS
Welcome back:
I'm glad to hear you got it going. Please feel free to let us know if you have questions in the future.
Sep 14, 2019 at 10:46 AM
POTGIETER 2468
  • 5 POSTS
Thank you so much for your help Joe. i would definitely do when i need help again. have a great week.
Sep 14, 2019 at 5:23 PM
  • 110,246 POSTS
Happy to help.
Sep 15, 2019 at 8:13 AM
