Engine starts will not rev and then shuts off
235,000 MILES • 5.7L • V8 • 4WD
DJAMESJSR37
Ran code test codes 33 and 44 replaced MAP and oxygen sensor. next code was 82 and 43, replaced replaced knock sensor and ignition. Control, ext.coil fires full time with ignition on. so I take it's okay. I have replaced about all but pickup coil. Reinstalled old MAP and code 82 keeps coming up.
Aug 27, 2019 at 4:34 AM
  • 55,709 POSTS
Does it run better on starting fluid? it sounds like the fuel pump is going out. To be sure here is a guide to help us test the fuel pressure:
Sep 8, 2020 at 5:11 AM
