Engine shuts off bogs down while on highway and stalls?
173,390 MILES • 7.4L • V8 • 4WD • MANUAL
JASON BROWN2
I need a diagram of the intake egr, pvc, carbon can.
May 30, 2016 at 10:49 PM
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure as well as vacuum leaks auto parts scans for free and rent gauge. if hoses are soft for vacuum replace them.
and
https://www.2carpros.com/articles/engine-stalls
Check out the diagrams (Below). Please let us know what you find.
May 31, 2016 at 2:54 AM
DAVID7158
  • 10 POSTS
When I put a load on and take it to 2,500 to 3,000 rpm's and let shift the engine bogs out and barely has enough power to move at 25 mph. Engine will completely shut off at this point if I open the throttle too far. This whole problem resolves itself if I park the truck and turn off for about ten to fifteen minutes.
Sep 3, 2020 at 5:30 AM (Merged)
Good afternoon,
This could be a couple of things.
Low fuel pressure from a weak fuel pump. The pressure needs to be checked.
It could also be a clogged catalytic converter. The back pressure needs to be checked to confirm.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
DAVID7158
  • 10 POSTS
Okay, thanks. I will look into it.
Keep us updated.
DAVID7158
  • 10 POSTS
This problem started after I replaced my rotor and cap. I forgot to include that.
Okay, start with verifying you installed it correctly.
DAVID7158
  • 10 POSTS
It should be. I put it back the way it came off. I did break the front screw thread so I got a c clamp on it.
Do the other checks.
DAVID7158
  • 10 POSTS
She has low fuel pressure and I don't know why cause I replaced everything in the fuel system injectors, pump, sending unit, fuel filter, the injectors came with a pressure regulator. The injectors are the mpfi upgrade over the sfi ones
What is the fuel pressure?
DKLEIN
when accelerating normal everything is fine, but if I tromp down regardless of speed it slows down and almost dies out the tach doesnt jump like the trans.is slipping but almost as if its dumping out
DENNYP
  • 1,824 POSTS
I dont recall a 4cyl in a silverado.Whatever it may be,you should check your fuel psi. If it's dropping off a lot under hard accelleration, you might have a bad fuel pump.
DAVID7158
  • 10 POSTS
22 to 23 psi.
What motor is in the truck?
DAVID7158
  • 10 POSTS
5.7 350.
Okay, Te specs are below.
Your pump is not working at all.
Fuel Pressure
Central SFI .................... 60-66 psi
SFI .................... 56-62 psi
DAVID7158
  • 10 POSTS
Okay, so pump is garbage then.
Yes, that is correct.
DAVID7158
  • 10 POSTS
Okay, thanks.
You are welcome.
Always glad to help.
CHARLENE3
I replaced intake manifold and gaskets. When I put everything back together, the engine will not stay running. Has a hard start, doesn't seem to be getting enough fuel. Ran just fine before replacement of gaskets.
HANDYRANDY1027
  • 8 POSTS
[quote:ba087d9683="charlene3"]Engine Performance problem
1997 Chevy Silverado V8 Two Wheel Drive Automatic 250000 miles
I replaced intake manifold and gaskets. When I put everything back together, the engine will not stay running. Has a hard start, doesn't seem to be getting enough fuel. Ran just fine before replacement of gaskets.[/quote:ba087d9683] sounds to me like your fuel pump is going out or mabe your fuel filter is stoped up. Try pouring a litle gas in the throtle body and see if it starts easy and runs for a moment. If it does try changing the fuel filter. On the driverside mounted to the frame right under the cab is the fuel filter. If that does not work change the fuel pump. Good luck.
8736ANDREW
The truck will start and run for about 2-4 seconds. Then the truck stops running. Fuel pressure stays at 50 psi. Has new plugs and wires and problem was there before all this was replaced. Also no codes present in the vcm.
  • 110,251 POSTS
It sounds like the security system is shutting it down. Is the light staying on or flashing? Have you tried a different key?
8736ANDREW
The key is not a chip key. The security light is not coming on at all. I dont think it has a security light. I only have the one key and I have used it for about 3 years.
PB_PAUL
Engine cuts out when I give it the gas, it will cut out if its running and parked or driving and I hit the gas fast but will not if I give it gas slowly, has no power. I have replaced the fuel pump and fuel regulator, cleaned the injectors, new fuel filter. I had a obd scan done and it brought up one code only saying fuel cap was bad, I replaced cap, I have checked all lines and seam fine. I did have the distributer out when I replaced the intake gasket, could it be off a tooth as I did not check timing afterward but runs smooth otherwise. someone sugjested catiletic converter bad? any sugjestions? I'm at a loss. Any help would be great!! thanks
  • 110,251 POSTS
It sounds like either a bad vacuum leak, or the catylatic converter may be plugged. If you drive it at night, when you stop, let the engine run and look at the converter to see if it is glowing red hot. If it is, it's plugged. Also, use a timing light to make sure the timing it right. A tooth off can cause many problems.
Let me know what you find.
PB_PAUL
thank you! I will have the local exaust shop check the cat and go from there.
  • 110,251 POSTS
NTAHTINEN
I have a 97 silverado that will start up fine and idle fine, but it seems as soon as it warms up the engine dies, i have recently replaced the fuel filter and fuel pump and I was wondering what else it could be?
JASONRAY
  • 213 POSTS
Sounds like the Ignition Control module is shutting down when it gets hot. Common! Replace it. If you want to be absolutely sure, when it dies, try to restart it. If it doesn't start, check for spark. If no spark is present, that's it.
MANZOLARRY24
  • 28 POSTS
When you try to start it runs then shuts off. Shows a 1626 code, replaced the key tumbler and tried the ten minute relearn. Have purchased a stellar alarms bypass module, but the wiring diagram does not show the right color wires for my truck. Does this year even have a factory security system in it? it looks like someone had removed something because there are wires cut coming off of the ignition switch.
STEVE W.
  • 15,423 POSTS
Cut wires are never a good thing. Sounds like it had an after market alarm/remote start or similar and they did not remove it correctly. That can always cause problems.
VATS started in late 1997. (does your truck have a security light?)
MANZOLARRY24
  • 28 POSTS
There was no bulb in the socket on the insterment cluster so I put one in it, I'm pretty sure the key has a transponder in it and the truck has the box by the ash tray that's supposed to be the BCM I believe. The other codes it put out are 0452, 0463, u1041. It will stay running if a constant supply of fuel is put through the air intake, and it has good fuel pressure at relief valve
STEVE W.
  • 15,423 POSTS
VAT used the resistor in the key, 97 wouldn't have a transponder.
P0452 EVAP System Pressure Sensor/Switch Low (fuel tank pressure sender)
P0463 Fuel Level Sensor Circuit High Input
U1041 - Electronic Brake Control Module Missing Data
I would get a good wiring diagram and fix the wiring, then see what it does.
Sep 3, 2020 at 5:31 AM (Merged)
TILLYMOMOF2
1997 Chevy Silverado 6 cyl Two Wheel Drive Automatic
When you are accelerating and idling it will lag and it seems to want to die. We have cleaned the carburator and put a new fuel filter and new spark plugs and wires in. Also put in fuel cleaner. Now we are just drawing a blank on what it could be. would you have any suggestions?
PEAR69
  • 1,482 POSTS
Are you sure this truck has a carburator? Is the engine stock? Did you change the distributor cap and rotor? How many miles on this truck?
PEAR69
  • 1,482 POSTS
What type of modifications did you do to the computer to put a carburator on this engine? In your PM you stated that you didn't change the "rotors". There is only one distributer "rotor". I do not mean the brake rotors--I mean the distributer rotor---and yes it will make a difference.
You say your engine has a carburator so I must take your word for it, and this rules out fuel injector problems--so--with 200000 miles on it; it's probably time to rebuild the carb. What type of carburator is on this engine? 4 barrel or 2 barrel? Is your fuel pump mechanical or electric?
Check the floats in the carb., they may be sticking. Varnish sometimes builds up and causes them to stick.
Check the spacer gasket between the carb. and the intake--it may be leaking.
JNOR
Several days ago I was driving and my engine just stopped. I had been driving on the freeway for about 10 miles. When I tried to restart it, it would turn over but would not start. After a couple minutes it started up. I continued on and about 5 miles further, it died again. After a few minutes it started. The next morning I was on my way to work which is about 20 miles it stopped 4 times. I took it to a Chevy dealer. They would not drive it to duplicate it but let it run for a couple days when it finally died. They replace the fuel pump, some kind of harness in the fuel tank and a oil pump switch. I picked my truck up and it was fine that day. The following day it died again. I took it back to the dealer and they could not find anything else wrong.
Up until the first time it stalled, I did not have any problems. When the truck had about 65,000 miles on it, they replaced a fuel pump but at that time when the engine stopped, it would not restart after a few minuets.
The dealer is stumped. Is there something else I could have them check?
