Engine will not stay running?
89,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JCTGEE94
The truck has been sitting since 2019 because of a bad water pump. It was an old lady's car. After she passed the daughter drove it a few times and the water pump went bad, and it sat. I changed the water pump, put a fresh battery in it and a new starter along with a new fuel filter. And 10 gallons of fresh gas. It starts up every time for about 1 second and then shuts off. I need help please. I'm thinking it's the security pass lock system but unsure. The truck is 4 hours away from my home and need to get it to run long enough to get onto a trailer or drive home. It's all original truck 89,000 miles.
Oct 30, 2023 at 7:16 PM
  • 55,732 POSTS
Yep, it sounds like the security system is engaged, to be sure when you crank the engine over does the security light flash. If so, the security system is engaged.
Here is how to reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
and this can help do a hard reboot of the system as well:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If the security system light comes back on after the reset the key code does not match the pass lock sensor. At this point I would have a mobile locksmith come out to do the job/program the ignition key. It should cost about $200.00. Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Oct 31, 2023 at 3:26 AM
JCTGEE94
So, my question would be; if all else fails and the relearn doesn't work could me bypassing the security system with the 2.2k ohm resistor work? And get it put of security mode and get it to run.
Nov 2, 2023 at 1:47 AM
  • 55,732 POSTS
I have seen people install a resistor, but I have never done it, but I did find this video I would try:
https://youtu.be/TQ9ASjcSoWQ?si=qMnTuFYYEqYZ4caQ
Please go over this guide and get back to us.
Nov 2, 2023 at 2:24 AM
