Starting/pulling issue
175,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
CHRIS N KINNA SMITH
Right now it will crank but not start. fuel pump comes on but runs more than just the normal couple of seconds.Then when it does start up it has a very rough idle and will pull great in reverse, but does not want to pull in drive. it will bog down (losing power) and eventually shuts off. Any ideas i am stumped.
Feb 7, 2018 at 8:38 AM
Good morning.
The first thing I would do is to have the actual fuel pressure tested. there may be a access point on the fuel rail that you can check the pressure. if you do not have a tester, you can rent one from a parts store to test.
Feb 7, 2018 at 5:44 PM
RENEE L
  • 1,260 POSTS
Hello,CHRIS N KINNA SMITH
Thank you for visiting 2CarPros. Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
If you need further assistance please come back to the site we are always happy to help.
Kindest regards,
Renee
Admin
Feb 8, 2018 at 7:01 AM
