My engine is hard to start?
250,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JESSICADABOMB
I changed injectors, fuel pump, crankshaft, now my truck is hard to start and when it does it shuts off within ten seconds and will not restart.
Jun 13, 2019 at 12:17 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like it could be a problem with your fuel filter. When the fuel filter on your vehicle gets plugged, or is getting plugged, it doesn't let all the fuel that it should pass through it. Your vehicle would be hard starting and shut off, no matter how much you press down on the gas pedal. I have included a link for you to go to below:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
However, on your vehicle, the fuel pump is an integral part of your vehicle's fuel pump control assembly and located in the fuel tank, so let's double check and make sure that is fuel pressure. I have included the proper fuel pressure for your vehicle in the diagrams down below. You can usually rent a fuel pressure gauge for checking your vehicle's fuel pressure at your local auto parts store. Please check your vehicle's fuel pressure and get back to us with what you find out.
Thanks,
Alex
2CarPros
Sep 2, 2020 at 5:30 AM
JESSICADABOMB
It has 40 psi. my dash shows a message of service stablitrak, traction control, and says engine power reduced.
SCGRANTURISMO
  • 4,897 POSTS
Stabilitrak on your vehicle is highly complex and you need to have a Chevrolet Factory Scan Tool to fix. But when researching this for your vehicle I did come across this Technical Service Bulletin (TSB) for this problem. The issue has more than likely caused your vehicle to go into "limp mode". Limp mode is designed to make your vehicle driveable just enough to get it to a repair shop. Once whatever is causing the vehicle to go into limp mode is fixed, it should reset itself. Please go through this TSB, in the diagrams down below, and get back to us what what you can do with it.
Thanks,
Alex
2CarPros
JESSICADABOMB
I am not able to get truck to run let alone drive it. When it does start I'm not able to give it any gas I can almost floor the gas pedal but the vehicle does nothing.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Is your Malfunction Indicator Lamp (MIL) or "check engine" light illuminated? If it is could you pull the Direct Trouble Code (DTC) for us. You will need a code reader to do this and I have included a link below if you are unfamiliar with how to do this:
Please go through the guide, if needed, and get back to us with any DTC(s) that are present.
Thanks,
Alex
2CarPros
JMONTALVAN
  • 6 POSTS
Truck turns on fine in the morning, but I park it for 30 minutes then it cranks cranks then it starts. Has a new precision pump pr#A44006, my gas gauge goes up only 1/4.Acted up after tech installed pump.It has new spark plugs and cables. Checked all air intake and everything is okay. Have scanned all information but no codes. We have checked cam and crank sensors but they are good.Any ideas!
Jan 25, 2021 at 3:46 AM (Merged)
Long cranking is normally a fuel issue. Unfortunately, I learned the hard way that new parts are not good parts. If this started after the pump then we need to prove out a pressure issue. I would start with getting the fuel pressure when this is happening
When you just turn the key on and do not crank the engine the pressure should be a minimum of 55 PSI. Another way to help prove the pump is to turn the key on so the pump primes, then turn it off and back on a couple times when this happens and see if it starts the truck. If it does then basically this is showing that the pump is not priming properly on the first key cycle.
Let us know what you find. Thanks
JMONTALVAN
  • 6 POSTS
I primed the key a couple of times and it does the same thing. Crank crank crank and then it starts and then I can smell a lot of rich gas. Odd parts is if I let truck seat for 4 hours it will start right away. When it is in a 40 minutes to 2 hour frame it does the long crank.pressure gauge with truck on is like 55 to 60 but when it is turned off it goes to 30.
Okay. A crank sensor will cause a long crank as well so how did you check it? Did you monitor the pattern with a lab scope? The long crank is a result of the ECM not having the crank signal and once it learns the engine position from the cam sensor it will start. So after it sits and the crank cools down it sends the signal.
Let me know if you just checked voltage or checked the pattern?
JMONTALVAN
  • 6 POSTS
My truck was checked with a scanner, which tech said that crank and camshaft sensors were good.
JMONTALVAN
  • 6 POSTS
Truck in morning turns right away and if I turn off and crank it up it will start right away. But if I leave it for 45 minutes to 2 hours then it does the long crank. So if you say that the crank shaft is trying to learn the position, how come it turns right away in the morning? That's the weird part.
SHAZAM29
Hard to start at times and seems to have gotten worse. I take off the resonator from the throttle body and it starts most the time when I do that, but i have to hurry up and put it back on before it shuts off.
Sorry if I wasn't clear. When the crank sensor gets hot it can fail. When it fails it will cause a long crank until the ECM learns the engine position through the cam sensor. It starts in the morning with no issue because the crank sensor is not hot yet.
This may not be the issue but based on what you are describing, this is the most likely cause.
Good morning,
I would start by checking the fuel pressure. Low fuel pressure will cause this issue from a possible weak fuel pump.You can rent a tester at a parts store for this test.
Is the check engine light on showing any codes?
JMONTALVAN
  • 6 POSTS
Okay, will check it out.
JMONTALVAN
  • 6 POSTS
Thanks.
THEBOSS
  • 31 POSTS
2003 silverado excessive cranking to start at times. 5.3 engine reguler fuel. fuel pressure 55lbs.A little low.I have replaced fuel regulator due to leaking and also installed check valve in line near fuel tank. but still cranks excessive at times. Shouldn`t check valve hold the pressure for starting? what could be the problem? thanks Jerry
  • 75,988 POSTS
Sounds like you need to replace the fuel pump -check valve
  • 75,988 POSTS
Also go to this link:
THEBOSS
  • 31 POSTS
Thanks rasmataz how can I e-mail you I do know there is a check valve in the fuel pump but the one I installed inline should hold the pressure up shouldn`t it? Thanks
  • 75,988 POSTS
Take the one out on the inline and concentrate on the fuel pump side-
THEBOSS
  • 31 POSTS
rasmatas,The check valve I put inline is on the pressure side before filter,(Is filter line the pressure line or side?) The company where I purchased it said that was the purpose of this check valve.What would you think?-Thanks-
THEBOSS
  • 31 POSTS
Hi rasmataz I was wondering if you had a chance to review my last reply on my check valve, it is an (inline check valve)that was installed inline on the filter line before the filter as close to the tank as I could get it but truck still has excessive cranking at times -Thanks-
  • 75,988 POSTS
Replace the fuel pump-before you do this check and test the coolant temperature sensor
THEBOSS
  • 31 POSTS
The temperature sensor test fine. -Thanks-
RIVERMIKERAT
  • 6,106 POSTS
Check for fuel pressure bleed down. Turn the key on and verify that you have around 55 pounds. Then turn the key off and see if the pressure bleeds off slowly or quickly. If quickly, the pump should be replaced and your secondary check valve is also not doing what it was designed to do.
THEBOSS
  • 31 POSTS
Thanks rivermikerat,he has been driving it and I`m going to change the valve (secondary)just to to make sure the secondary has failed, I have had new parts fail before. It will take me a few days to get back to it. I did not know the temp. sender fed info. to the ignition or the pump all I could do was an resistance test.( Is that why I was told to check it?) I`ll let you know after I change the valve again.-Thanks-theboss-
RIVERMIKERAT
  • 6,106 POSTS
I'm honestly not sure why he had you test the coolant sensor. Let us know how these new tests go.
THEBOSS
  • 31 POSTS
Well it`s been 2 days now and the secondary check valve seems to be doing the job. Wne I first started into this problem as noted the fuel pump pressure spec. is 60 psi but this truck has been running fine at 50-55 psi and thats what it is doing fine so far on with secondary valve,starts again within the 3 sec.range.will keep watching and post if it changes.Thanks again!
RIVERMIKERAT
  • 6,106 POSTS
Pleasure. Let us know if we can be of assistance in the future.
ANDREW MONTOYA
Hello sirs , I have a 2003 chevy 3500 6.6 diesel that cranks like a champ but would take a long time to start and now will not start at all , I changed the fuel filter and bleed the lines . Could it be the fuel pressure regulator ?
RIVERMIKERAT
  • 6,106 POSTS
It sounds like you have low fuel pressure, or a plugged fuel filter, check these links
and
let us know what you find :-)
ROBERTBARNES62
  • 83 POSTS
I have noticed that when i turn the key to start it will try to turn over but not crank up on the first try. i can then turn the key back to the off position and then turn the key to start and the truck will start right up. I then tried something that seems to work which is i will turn the key to on, but not all the way to start, then turn the key to off and then turn it to start and the truck cranks right up with no problem.
So I was thinking maybe a fuel filter or the fuel pump may be going out? What are your thoughts on this issue?
Thank you in advance!
  • 110,248 POSTS
It sounds like fuel pressure drop off. It can be caused by the pump or even a leaky injector. Have you checked fuel pressure to confirm what is happening?
Here is a link that explains how to check:
I have trouble shooting diagrams, but need to know if you own a scanner that can actuate the pump.
ROBERTBARNES62
  • 83 POSTS
I have not checked the fuel pressure. I can check it and get back with you. as far as a scanner I have a Matco scanner, not sure if it will actuate the pump or not though.
Jan 25, 2021 at 3:47 AM (Merged)
  • 110,248 POSTS
Do this. When you check the pressure, pay attention to how quickly the fuel pressure drops when you turn the key off. Then, do the same thing, but pinch the return line to the fuel tank to see if it is the same. If it is, then we have an injector issue. If it doesn't drop fast, then chances are it's the pump.
ROBERTBARNES62
  • 83 POSTS
I checked the pressure and this is what I have found. When turn the key the press goes up to about 50 psi and then immediately drops to about 10 psi. When running it is reading about 50 psi steady.
If I understand it correctly, when I turn the key it should be in the 50psi range but it should hold pressure and not drop back to 10psi immediately, right? If that is correct would mean that my fuel pump needs to replaced, right?
Also I must add that I put a new fuel filter and pressure regulator already.
  • 110,248 POSTS
Either the pump is bad or there is a leak. When you first turn the key on, it primes only for a couple seconds. Then, the pump will not turn back on until engine RPM's reach a predetermined point. Are you sure there are no leaks? When it does start, is there any black smoke which could indicate a leaking injector?
ROBERTBARNES62
  • 83 POSTS
I cannot find a leak anywhere. Have been under truck and don’t see any fuel leaks. I would think that for as fast as I lose pressure it would be a good leak and should be able to find it. When I start the truck there is no black smoke. I am leaning more to the fuel filter cause I can’t find a leak. Any suggestions before I put a new fuel pump in this weekend?
  • 110,248 POSTS
Since there is no black smoke and you see no leaks, I suspect it is the pump. Here are the directions for replacement. The first part is tank removal. The second explains how to remove the sender / pump. All pics correlate with the directions.
__________________________
2003 Chevy Truck K 1500 Truck 4WD V8-6.0L VIN U
Fuel Tank Replacement (Pickup)
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Service and Repair Removal and Replacement Fuel Tank Replacement Fuel Tank Replacement (Pickup)
FUEL TANK REPLACEMENT (PICKUP)
Fuel Tank Replacement (Pick-Up)
pic 1
REMOVAL PROCEDURE
1. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure.
2. Drain the fuel tank. Refer to Fuel Tank Draining Procedure.
See: Fuel Tank > Procedures > Fuel Tank Draining
3. Remove the fuel tank fill pipe.
4. Remove the evaporative emission (EVAP) canister.
5. If equipped, remove the fuel tank shield bolts.
6. Remove the fuel tank shield.
pic 2
7. Disconnect the fuel feed/return pipes from the fuel tank pipes.
8. Cap the fuel and EVAP pipes in order to prevent possible fuel/EVAP system contamination.
9. Place a suitable adjustable jack under the fuel tank.
pic 3
10. Remove the fuel tank strap bolts.
NOTE: Refer to Damage to Fuel Tank Straps Notice in Service Precautions See: Fuel Tank > Vehicle Damage Warnings > Damage to Fuel Tank Straps Notice.
11. Remove the fuel tank straps.
12. Lower the fuel tank until the electrical connections are accessible.
pic 4
13. Remove the fuel sending unit connector position assurance (CPA) connector.
14. Disconnect the fuel sending unit and pressure sensor electrical connectors (1).
15. Completely lower the fuel tank.
16. With the aid of an assistant, place the fuel tank in a suitable work area.
pic 5
17. Disconnect and remove the fuel feed (3) and return (2) pipes from the sending unit and retaining clips.
18. Disconnect and remove the EVAP pipe (1) from the sending unit, roll over valve (3), and retaining clip.
19. If replacing the fuel tank, remove the sending unit.
pic 6
INSTALLATION PROCEDURE
1. If the fuel tank was replaced, install the sending unit.
2. Install and connect the EVAP pipe (1) to the sending unit, roll over valve (3), and retaining clip.
3. Install and connect the fuel feed (3) and return (2) pipes to the sending unit and retaining clips.
pic 7
4. With the aid of an assistant, place the fuel tank on the jack.
5. Raise the fuel tank until the electrical connections can be made.
6. Connect the fuel sending unit and pressure sensor electrical connectors (1).
7. Install the fuel sending unit CPA connector.
pic 8
8. Install the fuel tank straps.
NOTE: Refer to Fastener Notice in Service Precautions See: Powertrain Management > Vehicle Damage Warnings > Fastener Notice.
9. Install the fuel tank straps bolts.
Tighten
Tighten the bolts to .....................................40 N.m (30 lb ft).
10. Remove the adjustable jack from under the fuel tank.
pic 9
11. Remove the caps from the fuel and EVAP pipes.
12. Connect the fuel feed/return pipes to the fuel tank pipes.
13. Install the fuel feed/return pipes to the clip on the fuel tank.
pic 10
14. If equipped, install the fuel tank shield.
15. Install the fuel tank shield bolts.
Tighten
Tighten the bolts to .....................................18 N.m (13 lb ft).
16. Install the EVAP canister.
17. Install the fuel tank fill pipe.
19. Install the fuel fill cap.
20. Connect the negative battery cable.
21. Use the following procedure in order to inspect for leaks:
21.1.Turn the ignition ON, with the engine OFF, for 2 seconds.
21.2.Turn the ignition OFF for 10 seconds.
21.3.Turn the ignition ON, with the engine OFF.
21.4.Inspect for fuel leaks.
________________________________________
Fuel Sender Assembly Replacement
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Tank Unit Service and Repair Procedures Fuel Sender Assembly Replacement
FUEL SENDER ASSEMBLY REPLACEMENT
TOOLS REQUIRED
J 44402 Fuel Tank Sending Unit Wrench
pic 12
REMOVAL PROCEDURE
1. Remove the fuel tank.
2. Disconnect fuel lines from the sending unit, if required.
3. Using J 44402 , remove the sending unit lock ring.
pic 13
4. Remove the sending unit and seal. Discard the seal.
CAUTION: Drain the fuel from the fuel sender assembly into an approved container in order to reduce the risk of fire and personal injury. Never store the fuel in an open container.
5. Clean the sending unit sealing surfaces.
CAUTION: In order to reduce the risk of fire and personal injury that may result from a fuel leak, always replace the fuel sender gasket when reinstalling the fuel sender assembly.
IMPORTANT: The fuel strainer must be in a horizontal position when the sending unit is installed in the tank. When installing the sending unit, assure that the fuel strainer does not block full travel of the float arm.
pic 14
1. Install a NEW sending unit seal.
2. Align the tab, and install the sending unit.
pic 15
3. Using J 44402 , install the sending unit lock ring.
4. Connect fuel lines to the sending unit, if required.
5. Install the fuel tank.
Let me know if this helps.
