Starts but does not stay running?
150,000 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
R WHITCHER
Van starts every time and be shuts off immediately.
Aug 21, 2021 at 3:03 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Are you having the security light flashing on the dash? Here is a security system-anti theft system reset to try first:
https://www.2carpros.com/articles/how-to-reset-a-security-system
The best thing to do is perform a check engine light diagnostic test . Here is a tutorial showing how to perform a check engine light code test:
After performing this get back to us with any code information and we can the properly diagnose the issue on your car. You might want to perform a fuel pressure test to rule out a weak or failing fuel pump. Here is a tutorial showing how to test fuel pressure:
The fuel pressure specification on your Astro van is 60-66 PSI with the key on-engine off. Hope this helps and thanks for using 2CarPros.
Aug 21, 2021 at 11:14 PM
