Starting problem
161,556 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
HADLEY BEUKES
Good day, I have a problem with my car a few months ago the Bendix of my starter broke it made a grinding noise and failed to start. I had the starter fixed, i replaced the Bendix and solenoid and had tested. it was working again the way it should after, but i am still having trouble starting my car. it turns over but will not start. I am desperate for help as I am disabled and need my car.
Oct 27, 2017 at 11:26 PM
  • 110,248 POSTS
If the car was running properly before the starter issue, something is telling me there is now an electrical issue. Are you certain everything has been put back together properly? Will the engine start for a few seconds using starting fluid? If it does, then there is a fuel related problem. If it does not, then it is ignition related. I think that is the first thing that needs to be determined. Once that is figured out, then we can focus on a specific system to find what is causing the problem.
Recheck the area you where you worked, Make sure nothing was disconnected, damaged.
Oct 28, 2017 at 10:29 AM
HADLEY BEUKES
The ignition harness was also replaced because it burnt and the battery is still new. the starter was tested it was fine. i am going to replace all the spark plug cables in the week as they look worn out and brittle. the car was serviced four months before the starter gave problems. just wish for the car to start. do you think i should replace the whole ignition?
Oct 28, 2017 at 9:30 PM
  • 55,743 POSTS
If the ignition is working then it should be okay. When the engine does not start does the ignition have spark? Here is a guide to help you find out.
Cheers, Ken
Oct 30, 2017 at 7:06 AM
HADLEY BEUKES
Good day I have checked the car for spark it has good spark somehow just doesnt wana start even checked the fuel no problem
Oct 31, 2017 at 7:42 PM
  • 55,743 POSTS
It sounds like low compression. Can you run this test to see what you find?
Cheers, Ken
Nov 1, 2017 at 11:25 AM
HADLEY BEUKES
Must my coil be very hot when i try to start my car?
Nov 10, 2017 at 12:48 AM
  • 55,743 POSTS
No it should not be, it sounds like you have a computer that is going out because the coil driver is not terminating the pulse signal which makes the coil hot.
Nov 10, 2017 at 3:13 AM
