Starting issues
170,000 MILES • 4.4L • V8 • 4WD • AUTOMATIC
LAFLARE
Drove my car listed above one day and it ran fine. later that night went outside to start the car and nothing happened. No lights, sounds, buzzers. Nothing happened. complete dead car. Whats the problem and how to fix? Oh and I just had a new battery installed days before this issue.
Nov 14, 2019 at 3:18 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you might be having an issue with the alternator not charging the battery while in use. Have you had the alternator tested after replacing the battery and having this happen? Here are a few tutorials showing how to test and replace an alternator:
https://www.2carpros.com/articles/how-to-replace-an-alternator
If you remove alternator and take to your local auto parts stores they will test for free.If you feel confident to remove/replace yourself and have tools I can attach step-by-step instructions for you.Hope this helps and thanks for using 2CarPros.
Nov 15, 2019 at 7:56 AM
JIS001
  • 3,412 POSTS
If this is a V8 4.4L I would recommend checking the passenger side inner axle boot for a leak. If it is leaking and got to the alternator then that will be the root cause for the alternator failure. To replace the alternator the axle would need to be removed. At that point it would make sense to replace both components.
Nov 21, 2019 at 1:43 PM
