Starting issues?
85,000 MILES
RAR3
My car listed above is a super beetle convertible that didn't crank over. I diagnosed and replaced to original starter. The starter turns the car over slowly but there doesn't seem to be enough juice in the battery to start, even after an overnight charge and jumping it with my SUV. The battery is only 3 years old. What should I look at next?
May 3, 2023 at 11:29 PM
  • 55,456 POSTS
It sounds like you got a defective starter motor but to be sure you can use a voltmeter at the main battery power cable and test the voltage which should be about 12 volts (same as the battery) also please check the main ground cable from the battery to the engine block.
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 4, 2023 at 5:24 AM
