Chances are either it is a fuel related issue or ignition. What I want you to try is this. See if it starts for a couple seconds using starting fluid. If it does and then stalls, we know it's fuel related. If it doesn't make a difference, then it's likely an ignition problem.
Here is a link you may find of interest. It explains the most common causes of a crank no start condition. Take a look through it and see if anything helps.
If there is no change with starting fluid, here is a link that explains how to check for ignition spark:
Start with these things and let me know what you find. This will help us identify on which circuit or system to focus.
Take care and let me know.
Jun 3, 2020 at 1:13 PM
