8 mo ago I had a new starter put in because when I would start the 1986 jeep cj7 renegade it would make a grinding metal on metal sound or make an obnoxious loud ticking noise and then grinding sound before starting. It was fine for a while but the same thing is happening again. Sometimes I get in and turn the key and..SILENCE. Nothing. I tap the starter with a hammer and it starts right up. What could be the problem? Going thru a starter every 6 mo. is not right. Can you help me out? Thanks!!
May 1, 2019 at 2:31 PM
