Engine swapped and starter is different location
133,000 MILES • 4.1L • V8 • 2WD • AUTOMATIC
C3
Car is listed above ht4100. Motor is 1985 Buick Riviera 307. This was supposed to be a direct bolt in. what I noticed is the 307 starter bolts to the block on the same side as the transmission. Am I missing something or was I sent the wrong 307 engine?
Apr 24, 2020 at 5:26 AM
Good afternoon,
Okay, I have done this conversion at all. I was told the 307Y motor would go in but there are differences. To be honest, I would have installed the updated 4.5 motor as a replacement.
Yes, the starter is on the other side and you will have to modify the wiring for it as well.
since this is a carburetor engine, the harness will have to be modified.
What have you done so far as wiring the engine?
Apr 24, 2020 at 6:15 AM
C3
Haven't made it that far with the build. But I did figure out the engine will fit. The stater doesn't bolt to the block. Thanks for responding and I'm sure I will have a million other questions.
Apr 24, 2020 at 6:20 AM
If I am not mistaken, if you have the 325 3 speed transmission, the starter bolted to the transmission bell housing.
Apr 24, 2020 at 6:24 AM
