idle air motor
WFLIER
1976 Cadillac Seville-48,000 miles, 350 (I think gmc was using Buicks engine then) GMC dicontinued part #1608797-now what? Engine races until warmed up. Any after device to use? Thank you
Apr 17, 2007 at 12:15 PM
TSOCALBEACH
The fast idle valve was discontinued years ago, and is neccesary for the operation of this vehicle. They can be found on ebay under seller name socal_brock (there is an underline between the name socal_brock). He has excellent original Cadillac parts, I've used before. He also sells the ECU Computer Coolant Sensor, Manifold Air Temp Sensor, TPS throttle position switch, Speed Sensor (distributor trigger) signals correct injection group to spray.
Apr 30, 2007 at 12:32 PM
