Starter
277,000 MILES • 4.8L • 6 CYL • 4WD • AUTOMATIC
KRENNING
My starter to change to stay engaged and park it in neutral only.
Aug 4, 2016 at 12:00 AM
HMAC300
  • 48,601 POSTS
this question is to mixed up please try to explain better.
Aug 4, 2016 at 12:32 AM
KRENNING
I have 98 Ford Ranger automatic I've changed the start ignition switch neutral safety switch starter interrupter relay in the fuse compartment in the motor and what's happening is I start my car in park and it you can hear the stars is engaged I go hit it and reverse it stops and I go ahead and neutral and comes back and gets engaged and drive it's not engaged and also I don't know if this has anything to do with it but I turn my key backwards and it starts and I'll start also when I hit it forward in the in the first position. I hope you can help me.
Aug 4, 2016 at 10:24 PM
HMAC300
  • 48,601 POSTS
have the work you did rechecked you may have the ignition switch in wrong , or there is a starter problem.
Aug 4, 2016 at 11:37 PM
