Engine Mechanical problem
1994 Ford Ranger 6 cyl Four Wheel Drive Manual
How do you replace the starter?
Saturday, August 8th, 2009 AT 8:42 AM
BLACKOP555
MECHANIC
Disconnect the battery. Then remove the wiring off of the starter from ther unbolt starter from tranny bellhousing and pull it out. If shimmed before try to the shims back in correct order.
