started shaking and check engine light came on
114,000 MILES • 6 CYL • FWD • AUTOMATIC
OLDDODGETRUCK
  • 66 POSTS
I was driving my 2001 Mazda 626 6 cylinder on a highway up a not very steep hill when it the engine shook and the check engine light came on. It stopped shaking when I slowed down, but it started again after I got a little above 2000 rpm or about 60 mph. I stopped and put it in park and started again, and the problem happened again for about 2 seconds, then went away. My only guess is the ignition coil. Any ideas?
Dec 1, 2013 at 5:17 AM
HMAC300
  • 48,601 POSTS
scan for codes it may have one stored in computer. or maybe you got some water or liquid on it to do that or mayb e apiece of junk got intot he spark plug like carbon then cooked out.
Dec 1, 2013 at 5:37 AM
TUKX
  • 9 POSTS
check ur ignition coil,ether 1 ov them is not working.try to remove spark plug cables 1 by 1..iv the spark is fine but stl shaking..then check the following ,spark plug,vaccum leak,temp sensor,catalic conveter/mufflur..iv all fine then get a scan tool.
Dec 1, 2013 at 9:28 PM
