Started dieseling real bad then overheating
3,086,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVID SEARCY2
Dieseling bad then overheating. changed thermostat, did okay for about fifteen miles then started doing same exact thing. car ha a lot of miles just trying to get it by for couple more weeks. any tips,suggestions greatly appreciated.
Mar 6, 2019 at 10:10 AM
  • 110,248 POSTS
When you say it started doing it again, are you referring to overheating? If so, you could have a couple different issues. First, keep in mind that an extremely hot engine can diesel when turned off.
I have questions. First, does the car only overheat in stop and go traffic or does it also do it at highway speed? If only in town driving, confirm the cooling fans are turning on when it starts getting hot.
Next, if it also happens at highway speed, confirm that the radiator isn't plugged. When the engine is cold, remove the radiator cap and confirm the coolant is full. Start the engine and allow it to warm up with the cap off. When it gets to operating temperature, the coolant should be circulating, If it isn't, then try flushing the radiator. Most parts stores offer an inexpensive flush kit.
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
If that isn't the issue and coolant flows, then I need you to check for a possible head gasket issue. Follow this link.
If you could, try these tests and let me know the results.
Jul 1, 2021 at 6:34 AM
